Thought I would start a thread showing progress on my oven. I have been waiting forever it seems for nice weather to start my build. Today I got tired of waiting, I covered the area with a tarp and layed the blocks for the stand today even though it rained 2 inches.
42" Pompeii in Kentucky
Re: 42" Pompeii in Kentucky
Looks great! You made quick work of those blocks.
Dave
Thanks for the comments. I would like to pour the slab next but after thinking about it a bit I think it will be much easier to lay the brick veneer on the front of the hearth stand before the concrete is poured. There will be a concrete ledge all the way across the front on which the pool coping will bond that will create the landing and I think it would be much more difficult to lay the brick after its in place. I knew this project would be labor intensive but this is going to be more work than I anticipated. By the way, I don't know if you can tell from the pics but the section of the hearth stand to the left will support a grill that will be recessed into the wall.Last edited by ckdickerson; 05-03-2010, 08:51 AM.
I started laying the brick this week. I worked on it a few hours after work each day this week. Mix one batch of mortar, lay four runs of brick, clean up the tools, strike the joints, and then repeat process the next day. It took three days to get this far but at least I'm almost finished with the brick for now. I should finish the brick tomorrow and then I'll start building the forms for the slab. It's hard to believe this all started from a simple question like.....Honey, what are we going to do with the left over brick from the house? I know........
I was going to pour the hearth ledge and allow it to overhang the brick by about 6" and then lay the 12" pool coping which would overhang the ledge another 6"for a total of 12" on the hearth. In order for the brick to work out right the ledge would be 3" thick. I don't know much about concrete. Should the 3" thickness on the ledge be sufficient and would the 6" of bond area be enough to bond the pool coping without any problem?
I just finished laying the brick. As I was finishing it started raining and splashed some mortar on the brick on the left side. I hope a pressure washer will take it off after it dries. Tomorrow I will start building forms. Can someone tell me if the perlite concrete will support the weight of the oven? I have cut my oven floor bricks to fit inside the dome walls and the dome will be built directly on the slab. I was just wandering if I should stop the perlite at the edge of the floor and build the dome on structural concrete or if it's ok to build the dome on the insulating concrete.
Originally posted by ckdickerson View PostI was just wandering if I should stop the perlite at the edge of the floor and build the dome on structural concrete or if it's ok to build the dome on the insulating concrete.
Great looking work so far!
DrakeLast edited by DrakeRemoray; 05-07-2010, 10:40 PM.My Oven Thread:
Thanks for the reply Drake. Yes I did download the plans. I was just a little concerned about the compresive strength of the perlite concrete. After the last post I did a little research and if I understand it correctly a 5:1 mix of perlite and portland is in the neighborhood of 300psi. I'm sure thats sufficient but somehow it just doesn't seem right. But then again I have never used this stuff. I need to just trust the plans and all of those of you that have been through this.
Originally posted by ckdickerson View PostAfter the last post I did a little research and if I understand it correctly a 5:1 mix of perlite and portland is in the neighborhood of 300psi. I'm sure thats sufficient but somehow it just doesn't seem right. But then again I have never used this stuff. I need to just trust the plans and all of those of you that have been through this.
Dave
