Though that i would start a thread with pictures of my WFO in progress of building.
My WFO started April 2010
Re: My WFO started April 2010
I have been waiting to do this part.. had problems finding the fireclay, but i think that i am going to order to by mail.Originally posted by eprante View PostYou have a good start. The slab, stand and structural slab are the parts that are the hardest work. Once you get to the actual oven build it is really fun. Good luck!
EricToby
Columbus, NE
Well its been awile since i have logged on here, but about have the oven finished. Had a couple of fires in it now, just some finishing touches and roof.. I have noticed that the back side of the brick up against the chimmy ( where the roof butts up against the brick gets pretty hot to the touch..anyone else see this on there's?5 PhotosToby
Columbus, NE
That part of the flue is pretty deeply buried in my oven, so I can't answer your question, the front stays pretty cool except right at the outer arch.
I like your full front chimney with the back roof configuration. What kind of shingles are you planning?
Thanks, I want to use the terra cotta round style roof tiles, but they are to expensive, so for now I am going to just use a imitation shake roof tile. but down the road if I can run across some I will change it out.
The chimmy will go up six total courses of brick and be capped off with red bullnose brick.Toby
Columbus, NE
Looks like tomarrow is suppose to be dry, hoping to pour the Hearth slab
