Progress! Finally! ...Sort of!
I had some threads earlier in the Getting Started section about the foundation that I was working with (I didn't make it), which wasn't level. I was finally able to get time to mortar the stand together. I haven't poured concrete into the voids of the stand yet, but I thought I'd share some of the photos of the mortar'd structure.
We did this last weekend, when it was so hot that the mortar would set within 3 minutes. The bottom two courses of cinder blocks had to have mortar mixed for two blocks at a time. It rained later int he day and that gave us about 20 minutes of working time per mixed batch.
There were also mistakes, pictured below. The batch of cinder blocks I got from Home Depot were of differing sizes, so I had to shave material off of some of them to make the stand fit together. The last course was laid in an improper sequence, so there is both a gap and an overhang. The leftmost wall is also a little bit skewed. I think this is because the bottom course of cinder blocks had to have the least amount of material removed via diamond saw (under an inch) and it was hard to maintain accuracy when cutting that shallow. Should I let these mistakes slide, and just try to cover them up? To the left of the stand is a basic grill that I decided to throw together as long as I was stacking blocks. This should buttress the stand in case the leftmost wall is weak.
