Re: The Backofen
Trellis - Depends on how long ago you set those bricks. If it were me, and the bricks had been in place less than 48 hours - I would take a cold chisel and a rubber mallet and see if you can knock off the top two chains and redo them. I had a much less severe problem with the angles on my oven, and ended up doing this for one chain and I am very happy I did.
However, IIRC - you are using HS50 - which in my experience sets up quite a bit faster - so you might not even have that much time.
If the mortar is too set up, then removing the bricks is tricky. If you are following Texman's thread, you'll see what can happen. He ended up having to start over when he cracked his oven.
