New pics of the oven with a finish coat of stucco.
Stucco Done
Stucco Done
3 Photos“Never regret. If it's good, it's wonderful. If it's bad, it's experience.”
Trellis
Home Sweet Home~ Colorado Springs ~
sigpicTags: None -
Re: Stucco Done
Its Acrylic..“Never regret. If it's good, it's wonderful. If it's bad, it's experience.”
Trellis
sigpicComment
Re: Stucco Done
I used an acrylic product called A-100 and so far, thru one rainy season and the tropic sun and the heat from the oven, it has held up perfectly. My only concern might be that in order to refinish at some point in time, that I may have to power sand down to stucco to get the best adhesion. I really like the coating and also used it on some slate trim at the transition to the patio.Comment
Re: Stucco Done
[QUOTE=Laurentius;140746]What is your door made of?[/QUOTE
2mm steel, double wall, filled w/perlite, pipe fitting welded on for the thermometer and 2 long bolts for the wood handles. Not too heavy and really does keep the heat inside the oven.Comment
Re: Stucco Done
Next time do not cut off the closing bracket "]" and the quote will format better
ChipChipComment
Re:Like putting the Star on the Christmas Tree!
I am so near to finishing the Project.. put the chimney cap on yesterday..It was like putting the Star on the tree at Christmas..the only thing I have left to do is
install a Dial Thermometer in the door ..This has been the biggest project undertaken by me..Thanks to all fellow Forno Bravo POB's
(Pizza Oven Builders), for pictures..suggestions and to Forno Bravo for putting the plans on the internet for FREE!5 Photos“Never regret. If it's good, it's wonderful. If it's bad, it's experience.”
Trellis
sigpicComment
Re: Stucco Done
Couple more pics! Huge thanks to my friend RICH!
Trellis
sigpicComment
Re: Stucco Done
Wow your fire codes are much less restrictive than ours I had to be 15 ft from the house, fence and any other combustible structures. Pizza and oven look great, I like the rock around the chimney.
ChipChipComment
new pic
Turkey brining tonight .. going in the oven tomorrow! Made Pork Carnitas last week and they were the best ever! Door is done, so the only thing I have left is the cobblestone patio next year! My Initials and year are out about 2 1/2" out so that creates a handle.. I know its off a little bit.. adds to the character ..1 Photo“Never regret. If it's good, it's wonderful. If it's bad, it's experience.”
Trellis
sigpicComment
Re: Stucco Done
I put ours in the brine about an hour ago. I had another thread going but how are you handling the fire; tonight or tomorrow? I opted to fire up tomorrow and we will see how that goes.Check out my pictures here:
If at first you don't succeed... Skydiving isn't for you.Comment
