Re: 42" build in Virginia
Gudday Fabby
I feel you pain buddy, you are definitly betwwen a rock and a hard place.
You have the best advice here from a brick layer who can build an oven, multiple caste oven builder, a stone mason, and dejayoh( firewood entrance arch is awsome).
If anyone can talk you through this and build an arch its is those bunch.
I'm only a mug builder have a entrance with a lintle due to my poor brick laying skills. I'll be the first to say its not best practice,its prone to rust cracks from uneven expansion, all of everything that has been said, my oven continues to work however.
Be happy with any decision you make
Regards Dave
You could try something like what I did with my firewood storage area. I built an axed arch as a decorative finish that had to fit into a square opening, and was surprised by how sturdy it was, even using voissoirs (love these brickie terms!)
You could do the same with the bricks on their long side. Cut to fit the square shape from the back ~2-3 inches of each brick to fit into your oven opening, but have the strong part of the arch built with the rest.
kind of convoluted, I hope it makes sense.3 PhotosLast edited by deejayoh; 03-31-2013, 05:52 PM.
Casting would be a good idea, but you should be o.k. if you go with firebrick. Don't forget to cut your form a little less than the total height of your finished arch, then use wedges to raise up the form. When you are done with the arch,pull the wedges out, the form drops, and you have an arch.
You could always cast the arch.
You probably need to build an arch to support the opening, also, your little reveal pieces will just fall off over time like they have now.
My daddy always taught me, he said "mikey, never force anything, just get a bigger hammer"
Well, I have never ordered pizza with zinc fumes on it at the pizzeria, so I figured I wouldn't offer it on my menu either.
Harbor freight has a pneumatic hammer with the attachments. My brother, who is the "toolman", just happened to have one in stock. Go figure. He has everything.AND, it has never been used!!! Perfect for removing that big ass piece of galvanized angle iron without destroying my baby.
I hooked it up to my air compressor and within minutes, I have a new hole that is unsupported.
What do I do now, I need some serious help.......please?
I'm out there, and I'm loving it! (that's a Seinfeld tv show reference to going camando for those that don't know)
3 Photos
ingesting zinc is different from inhaling the fumes it produces.
Bummer. I never gave a thought to the type of metal, but it sure looks galvanized. The pieces I used on the stand were left over from a builders stock. I was originally going with an arch form but then it just became to complicated
What should I use instead, and what is the best way to remove this as the bricks an refractory are atached?
Hell, I take zinc for my prostate.......galvanized can't be all that bad on your pizza
The steel being more conductive attracts the heat and gets much hotter than the refractory surrounding it leading to expansion that the refractory can't handle. You may be able to drill and chip the refractory at each end to provide some expansion space that might work. Regarding the galvanized, if it is, you should remove it. Research zinc poisoning.
I hope you havent progressed too far since that last pic.
Steel lintels and wood ovens dont work too good together, even worse its galvanized.
The zinc may poison your family, or is that the plan.
closing in on the dome. man, this is a lot harder than I thought. cracking bricks, keeping them from falling.............................I am on my fourth 50 lb back of refractory mortar. WTF?
I am in Powhatan Virginia, just west of the Capital city of Richmond.
Stop in and take a look if you are in the area.
cheers.3 Photos
Looking good! Snow huh?...what part of VA?
Here is a pic of the entrance. If you look closely, one can make out the pencil drawing and the angle iron of where I plan to make my arch.
My question, how large of opening do I allow for the vent to draw, I have seen 6" x 10" but this seems too deep?
Some domes look to have a 3" or 4" depth. Any thoughts?
Thanks and Happy Easter everyone1 Photo
