Re: Rocket Stove Brick Oven
I have absolutely no idea if this would work but I was thinking of you could extend the horizontal tube around the oven base to create more even heating.
I don't know if all the 90 degree turns would work in the drawing below (my limited understanding is that it would need more heat) but this would move all the hot air around the oven base.
Perhaps the dividing walls could be made of Hebel or some other insulator (as in forming up a maze with vermicretre, etc). The roof above this maze could be heatbricks/clay pavers/thermal mass. In theory all the heat wuld move to the heatbricks as the rest is insulation???
The big black part is the chimney/entry into the oven dome. The drawing is looking down, through the thermal/oven floor. The orange arrows are hot air (hopefully). The big orange bocks are insulation/walls.
The more I think about it, if the design followed this path, the firing tube would need to be a big MF, to get all the way around the floor before firing up the chimney. This would obviously depend on the thermal mass being heated.
