Hendo's Oven
  • Hendo
    • Oct 2006
    • 257
    #16
    Re: Hendo's Oven
    Thanks Neill.
    With thoroughness comes delays however! I look with envy at others who put these things up in a few days, and I'm still wondering how I'm going to overcome the next problem, which no doubt exists only in my mind! I have many people in this forum to thank for continued encouragement and motivation.
    Good that it's the 'last' daughter - my project was delayed for similar reasons, but only the one (daughter/wedding) last year so the finances are starting to recover!
    Drop me a private message if you like, but I'd be interested in hearing more about the door project - I used to work at BTM at Kilburn, with the Stewarts & Lloyd's foundry across the road, so know a little about pattern making for cast iron products etc, and would like to learn more if you care to share. McKechnie's wouldn't be the foundry of which you speak, per chance?
    Good to hear from another Adelaidean.
    Cheers, Paul.
    • wlively
      • May 2005
      • 384
      #17
      Re: Hendo's Oven
      Hendo
      Beautiful work so far. It looks like you could drive a tank over that hearth!
      Wade Lively
      • carioca
        • Sep 2006
        • 266
        #18
        Re: Hendo's Oven
        Hello there, Hendo!
        I snuck a quick view of your project before Easter - but was so gobsmacked by the professionalism and thoroughness that I was briefly lost for words! (That from a journo...)
        But others have expressed well the unstinting praise you deserve! Splendidly detailed photos, too! Thanks for sharing the experience...
        My own haphazard project is still at the hearth curing stage (I poured the slab on Tuesday - pic attached).
        Cheers,
        Carioca
        • DrakeRemoray
          • Mar 2006
          • 1215
          #19
          Re: Hendo's Oven
          Excellent work Hendo (and you too Carioca). The boys down under are showing us how it's done!
          Drake
          My Oven Thread:
          • daz
            • May 2007
            • 3
            #20
            Re: Hendo's Oven
            thats a very serious construction hendo ,have you started the dome yet?
            • Archena
              • Apr 2007
              • 1214
              #21
              Re: Hendo's Oven
              Originally posted by Hendo
              The blocks are designed to interlock with adjacent blocks and the course above, so once the first course has been laid in mortar (to compensate for any unevenness in the slab), the remaining courses are dry laid. Mortar thickness varied from ?? at one corner to a little over ?? at the opposite corner, so the slab was reasonably level. The blocks are 8? high and are bevelled on the sides and top, to simulate a ?? mortar joint. Laying these blocks was very satisfying work, as it all goes up so quickly!
              Wow!
              Question, what are those blocks called? I assume my (eventual) supplier can order them. That is so totally cool!
              Thanks!
              [/CENTER]
              • Hendo
                • Oct 2006
                • 257
                #22
                Re: Hendo's Oven
                Archena,
                It's called the Connex Mortarless Block System and is produced by Boral Masonry. You can download a detailed info sheet at http://www.boral.com.au/mdg/pdf/connex.pdf if you're interested.
                It was developed in Australia, so I can't comment on its availability in the US.
                Good luck!
                Thanks to all for your kind words and encouragement - it has been bit wet here lately and I still haven't started the dome. However, other priorities have kicked in, like home maintenance, re-constituting the back lawn after all the activity and trenching, and re-vamping sub-floor cabling for various electrical toys, etc etc.
                Cheers, Paul.
                • Archena
                  • Apr 2007
                  • 1214
                  #23
                  Re: Hendo's Oven
                  Thanks! I really appreciate it!
                  [/CENTER]
                  • jengineer
                    • Aug 2005
                    • 572
                    #24
                    Re: Hendo's Oven
                    I have not searched for them but they must be available in the US. We blew through Fresno a few weeks back and a friend of the wife's is in a new cookie cutter home AND they have a backyard! The block wall around the property did not have any concrete seams. That implied to me that interlocking blocks are available - I did not get a chance to roam around the neighborhood to find the source of the blocks. I will drop them a line and see if they can find out.
                    • Archena
                      • Apr 2007
                      • 1214
                      #25
                      Re: Hendo's Oven
                      Cool!
                      I found a company subsidary in the US but it only makes bricks so I'd pretty much given up on finding them here.
                      [/CENTER]
                      • Unofornaio
                        • Jun 2007
                        • 323
                        #26
                        Re: Hendo's Oven
                        Why the tar paper under the brick in this application?
                        • Unofornaio
                          • Jun 2007
                          • 323
                          #27
                          Re: Hendo's Oven
                          Originally posted by Archena
                          Cool!
                          I don't know where you are at on your build but I found this thread so I thought Id reply. These types of interlocking blocks are becoming more and more popular. I have a buddy that did a wall and ordered them from Lowe's several years ago. I'm sure Home Depot carry a similar product. You may also want to check with you local masonry yard to see if they have any "seconds" which to them is at the very least least a pallet. Last summer I purchased a version of these blocks that require a bed joint but not a head joint @ .55 for 6x6x18..heck I didn't care they were going to be stuccoed over. Here are some links I found:
                          Azar Mortarless Building Systems Inc.
                          VOBB dry stack concrete blocks
                          • Hendo
                            • Oct 2006
                            • 257
                            #28
                            Re: Hendo's Oven
                            I'd have to ask the brickie, but I understand the inclusion of some sort of 'damp course' is standard practice to prevent damage due to rising damp - called 'salt damp' here. Quite common in older houses (at least in Adelaide) where the salts in the rising damp crystalize (I think) and ultimately turn the mortar to dust. Debatable for a small structure like this, but having seen what salt damp can do, we erred on the side of caution.
                            • Bacterium
                              • Apr 2007
                              • 560
                              #29
                              Re: Hendo's Oven
                              your on the money Hendo...after chatting with my brickie.
                              The alternate I used to that was I put plastic (Fortecon) under my first pour
                              Damon
                              Build #1
                              Build #2 (Current)
                              • Archena
                                • Apr 2007
                                • 1214
                                #30
                                Re: Hendo's Oven
                                Thanks! I had found some a few days after making that post but I didn't have one of those links!
                                'Preciate it!
                                [/CENTER]
