Hi all,
A bit of context...
I'm based in the uk. Have been making pizza and breads enthusiastically using an indoor electric fan oven and pizza stone for quite a while now. Having just bought a house and planning a garden refurb, I'm considering a self build wood fired oven. We have a large ish garden, few close neighbours despite being in a very busy part of manchester.
Local regulations allow for an outdoor oven as long as it doesn't have a roof as that would count as a fireplace and would have to be smokeless!
I've had a good look through the forums but my apologies if any of this has already been covered.
I know with a wood fired oven high heat and a long retention of that Heat are often prime concerns, I have a few things I'm unsure about relating to this...
As I understand it, a high heat is desirable for creating traditional thin crisp pizzas inonly a couple of minutes, this heat is created by a large thermal mass (thick walls, good amount of thermal mass for storing heat and a good refractive outer shell?) this also means a long time to get up to temperature and a long cool down period. Am I at least close so far?
As I'm quite happy with the results of my indoor oven running at 230-250 degrees (I favour a New York crust) and my reasons for outdoor oven are more about outdoor living, sociable cooking and a smokey flavour, would it be sensible to have less than maximum thermal mass to allow a quicker warm up and less fuel required?
I'm intending to build a small ish oven based around some of the oil drum designs I've seen on the forum. Essentially a half oil drum on a stand with firebrick oven bottom and conventional brick arch over the top.
I intend to cook pizza, bread and roast meats along with some other things... Jamie Oliver has a lot to as wer for in our house!
In order to cook bread and roast meats will it be necessary to have some sort of door and mechanism to close the flue to retain heat?
I'm also condidering placement in the garden. I suppose it goes without saying that no trees can be directly above the chimney, how far away from trees should I have the walls of the oven? How much heat would I expect radiating through the bricks? One of the ideal locations for the oven would be right up against a wall of the house but I don't want to give myself any issues with heat conducting into the house walls and cracking bricks or mortar?
Any thoughts or advice gratefully appreciated.
Thanks in advance.
Tom
A bit of context...
Thanks in advance.
Tom
