Casa 90 corner build (and outdoor kitchen) begins....
  • terdferguson
    In the meantime I also built my brick arch:
    And filled it with wood.
    The rest of the wood went in my garage:
    The best part of all is that my father in law is a cabinet maker. He has an endless supply of maple and oak kindling for me. Yes please!
  • terdferguson
    I put the durock on top of my wfo. Sealed and taped all the seams. Then it was on to reguarding the wfo and my counter. I put on two coats. It came out well! I feel pretty good about how waterproof the oven will be with the redguard.
ID:	387953 Click image for larger version
ID:	387952 Click image for larger version
  • terdferguson
    Thanks for the reassurance.
    So I'm wondering if I should put my durock on top of my oven housing and seal it up now. Or should I keep building fires and driving out moisture while the top is off?
  • deejayoh
    yes, a new oven takes bit longer to clear due to residual moisture. If you are on day 7, you're probably getting ready for some pizza! And small cracks are normal. All ovens crack.
  • terdferguson
    Thanks deejayoh. Next question...is it harder to clear new ovens because of moisture? I'm on day 7 of my curing fires so today I kind of let it rip. Took some work to get the thing clear, but maybe that's normal, I don't know.
    Had some pizza tools arrive. I got the blue handled metal peel. One of you guys is obsessed with this thing, commenting all over the site about it. I forget who it is, but I bought it off of that recommendation.
    Also had some wood delivered...
    Yeah my wife's not too keen on the current state of the backyard.
    Built my form for my wood storage area arch.
    Watched my dome clear for the first time and saw some cracks appear too. I've read in thread after thread that this is normal and ok, but now would be a good time for one of you to say...terdferguson, that's normal and ok so I can remain calm.
  • deejayoh
    It needs to be coals before you put on the door. If you have a lot of unburned material, it will smoke as it goes out.
  • terdferguson
    Last night I made a fire. When it was time to put it out I put on the door while the fire was still burning pretty well. Smoke starting pouring out the cracks around the door like crazy. This morning I walked outside (12 hours later) and it smells like smoke outside! I open the oven and smoke pours out. The thing is still smoking 12 hours later! That's not good for the neighbors, not good at all. This didn't happen when I put out the other fires this week. I'm guessing I needed to let it die down before I put on the door? Any tips for how to put out the fire in as smokeless manner as possible?
    It is probably release agent left over from the cast. It will go by by soon enough lol.
  • RandyJ
    I am guessing that you maby burned some soft wood like pine. That will produce more creosote faster. But yes once you get up to pizza temps it should burn everything away that is not supposed to be there.
    Randy
  • deejayoh
    Originally posted by terdferguson
    I assume that whatever that substance is, it will get obliterated when I get up to full temp?
    This. unless it's some material that can stand up to 1000 degree temperatures!
  • terdferguson
    In the meantime I've started my curing fires. I've left off the top piece of durock on the wfo for the curing process. Here is my first fire:
ID:	387341 Click image for larger version
    I've noticed a small area of sticky substance on the roof of my dome. Is this normal? A byproduct of low heat fires? Or something on my dome from forno bravo?
  • terdferguson
    Yesterday I got all my seams taped and covered with thinset.
ID:	387336 Click image for larger version
ID:	387337 Click image for larger version
  • terdferguson
    Got all my durock up last weekend.
ID:	387332 Click image for larger version
    At the same time, I had the flue installed. I had my contractor who built my roof come out to do it. The flue goes through the ceiling.
    I wonder if there is any difference in the amount of heat transferred to the brick arch via a dome made out of refractory cement (like mine) vs fire brick?
    The thermal conductivity of most dense castables is the same as that of most dense firebrick.
  • deejayoh
    My experience is that most of the heat that escapes the oven is going up the chimney.
    Now, I do have a heat break between my vent and my dome - which probably reduces the temps somewhat - but I think this comes more into play after the oven is closed up. When it's lit - you have 800 degree gasses passing through the vent, which pretty much cancels out the heat break.
    IIRC, I think I've hit those bricks with my IR gun before and they're in the 120-150 range. Not too hot to touch, by any stretch.
