Originally posted by jonv
View Post
Jonv: There are advantages and disadvantages to each style of dome/cooking floor placement. The bottom line is that either method works well...do what fits best with your plans and comfort level as DeeJayoh noted. My build put the dome on the cooking floor and I've had no problems. As you have mentioned, there are plenty of builds done this way but just as many done with the floor bricks cut and set "inside" of the dome.
UnderPendle: Consider some prep or utility carts to roll under your cast span/cantilever. As a sidenote, my cast span (with ash drop ) made me a bit nervous when I was planning it...nobody would give me an opinion on it working or not. Your span/cantilever is much bigger than mine but it sounds like you've got solid engineering on your side. If it was me (because I'm chicken), I'd be putting a steel post on either side--back 30 cm or so from the edges--and then running some solar LED holiday lights on the posts to make the oven look like it was floating (and to ease my non-engineering mind).
Watching with interest and admiration...
