Just a thought. if the reasoning behind not mortaring the dome to the hearth is expansion. would the same be achieved by laying the first course on newspaper? and hence giving the dome a more stable base.
I have no experience of ovens whats so ever so forgive the daft observations but with a well insulated build, I would have thought the expansion of the dome and hearth would be very similar, the coefficient of expansion obviously the same using the same materials.
I plan on 100mm 28kg blanket immediately over the fire brick, and then a vermicrete mix on that. To the rear of the oven this void will be completely filled. I plan to build on this area as part of the flue. initially with a vermicrete mix, but then also some structural concrete.
Suppose what I'm getting at is how much will this lot move?
S
S
