After months (years?) of lurking around these forums, I finally started stacking blocks this week. I wanted to start building in early March, but it took about 6 weeks to get approvals from the county and the homeowner association.
I'll talk through my thought processes, since it has been enormously helpful to me to read others'.
My goal was to expand my 8x12 patio slab a bit and put the oven and an enclosed grill on one side. Since I wanted to do a bigger patio, I decided to have pros do the slab. I had them lay concrete 6" thick on the third of the slab where the oven would be with the rest of the slab 4" to save cost. The slab is reinforced with #4 rebar spaced 18" on center.
I wanted the oven to be convenient to the kitchen, but also I wanted an open view of the back yard from the kitchen. So, I settled on a patio layout that has the oven at an angle to the back door. I put a curve one side of the patio so that the corner of the angled oven wouldn't put extra stress on the side of the patio.
I was originally aiming for a 36" oven, but the size of the blocks forced me to add a few inches to the width, and the ceramic fiber board insulation that's locally available only comes in 2x24x48, with 2 boards in a box. I decided to go with 4" of ceramic fiber all the way around, including 2 layers of 2" fiber board under the floor, and 2 layers of 2" blanket everywhere else. It's probably overkill, but my thinking was that you can't have too much insulation.
So, since I have a 48" square of insulation and a bigger platform that I planned, it seemed to make sense to go for a 40" oven. I decided to compromise on 38" in favor of quicker heat up times.
I started stacking blocks yesterday morning, and so far I've stacked the blocks, poured the cores, poured the hearth, cut and stacked the insulation, and laid out the cooking floor. I mixed all the concrete in a tub with a hoe. If I was going to do it again, I'd definitely buy a concrete mixer on Amazon for $140.
