O.k. guys...I just found out that the hip bone is connected to the leg bone, the leg bone is connected to the knee bone, etc. etc. If your hip is crooked- your feet won't work!
Take a look at this pic I've attached and see if you can spot my first mistake:
See it?
O.k. so I came to the realization before I started this project that there is no way a novice like me is going to end up with brick work like Les. As long as the dome doesn't cave in, I'll be a happy guy. I'm doing a lot of eyeballing rather than exact measuring. I'm covering it all with a gable house though- so only the inside needs to be presentable.
I'm on my third course now (no pic of that yet) and as the course meets the arch, the left and right sides aren't even. In fact one side of the brick is dips into view slightly when looking through the arch.
That's because when I first laid out the arch towers, rather than cut one of the soldier course bricks lengthwise, I cut the archtower to accomodate a full brick! Had I cut the full brick and left the two arch towers identical, the dome courses would be lining up. Nothing a grinder won't fix- but a good note for the other novices out there getting started not to make this mistake if you are going for a highly esthetic looking dome.
See it?
