Work so far
  • aureole
    • Jun 2008
    • 97
    #16
    Re: Work so far
    Eighth course in, tomorrow the final course and the keystone (hopefully). Need to cut some bits to make it fit nicely.
    Matt S, Cambs, UK
    42" Pompeii
    Pizza oven pictures - WIP!
    Pizza oven costs (so far!)
    • aureole
      • Jun 2008
      • 97
      #17
      Re: Work so far
      Keystone in- just! The final course ended up with me cutting about a dozen bricks badly until I finally got the angles "more or less" right.
      Now I get to leave it for a week, then try a few test fires. Got a vent to cast in the meantime too!
      Matt S, Cambs, UK
      42" Pompeii
      • christo
        • Feb 2006
        • 913
        #18
        Re: Work so far
        Looks really good! I like the look on your face in the picture - I recall having a similar look when my oven was finally a complete dome.
        Christo
        My oven progress -
        sigpic
        • Ken524
          • May 2007
          • 1655
          #19
          Re: Work so far
          That'll make a heck of a pizza! Nice work.
          Ken H. - Kentucky
          42" Pompeii
          • egalecki
            • Mar 2008
            • 1049
            #20
            Re: Work so far
            pat yourself on the back. It looks good. I wanted to run around the back yard singing the theme from 'Rocky' when I got my keystone in!
            Good luck with the vent!
            Elizabeth
            • toddj
              • Aug 2008
              • 117
              #21
              Re: Work so far
              wow congrads! looks great!
              • aureole
                • Jun 2008
                • 97
                #22
                Re: Work so far
                The last course was crazy- I cut a full set of wedges and realised I'd cut the wrong angle - you really need two cuts to make a nice final course on the vertical and horizontal, but experimentation showed me that ain't going to happen on witha 7" tile saw! The lucky thing was I still had enough muck in the bucket to set the keystone and about a dozen offcuts to make a perfect fit to close the gap. Better still, I have an offer from a builder friend to do a "proper" render on the outside of the oven with a terracotta scratch coat.
                Got some horrible grazes on my arms where the lime worked into the cuts though - back to work tomorrow and going to heal up for a little while.
                Matt S, Cambs, UK
                42" Pompeii
                • sarah h
                  • Sep 2007
                  • 567
                  #23
                  Re: Work so far
                  Congratulations! It looks great! Feels good to reach that milestone, doesn't it?
                  You say now that you're going to heal for a while but I bet it won't be too long ...
                  • aureole
                    • Jun 2008
                    • 97
                    #24
                    Re: Work so far
                    Big progress this week/end.
                    In the week I cast my vent - I'd made the mould a long time back and hadn't got around to doing anything with it. I went for ~12" tall and the size of my landing (12" x 19"). It cast alright, though the castable concrete is weird to mix (the "ball in hand" test is quite hard to get right). It popped out of the forms without a hitch at all though. Bloody heavy at 50kg (~110lb).
                    I made the front arch - then realised that the front arch was about 3" shy of the vent, so I had to hastily run another set of firebricks to make up the gap above the arch - these will be concreted over so no-one will ever see them though! The front arch is the height of the inner dome entrance (12"), and the vent is about 3" taller, so the smoke will have to dip down quite some distance (and that vent is pretty big), so I'm hopeful no smoke will escape.
                    I put the blankets on and struggled with chicken wire for some considerable time: it's got a mind of its own, and if it wants to bulge out, I couldn't stop it. 2" of blanket all around, then I added about 3" of vermulcrete. There seems to be some weird bubbles and wrinkles in the finish - not sure there's much I can do about that apart from hope it stays down!
                    So, huge progress, only thing left is the chimney, final render and firing!
                    Matt S, Cambs, UK
                    42" Pompeii
                    • egalecki
                      • Mar 2008
                      • 1049
                      #25
                      Re: Work so far
                      I know it's too late now, but I used a pair of needlenose pliers to twist the chicken wire. Just grab a spot that's sticking up and twist a bit and it sucks it right down! I got a reasonably smooth finish on mine that way.
                      your oven's looking great. I think your render will hide anything you're not happy with...
                      Elizabeth
                      • aureole
                        • Jun 2008
                        • 97
                        #26
                        Re: Work so far
                        Great tip, though, thanks!
                        Matt S, Cambs, UK
                        42" Pompeii
                        • aureole
                          • Jun 2008
                          • 97
                          #27
                          Re: Work so far
                          Finally, had a professional builder friend round to render the dome: he did a much, much better job than I'd manage: it's looking incredibly smooth, and the final coat goes on next weekend (I'm going to get a bit of colour in it for a terracotta finish). So, firings will be starting up soon -the goal is to be cooking by the wife's birthday!
                          The cats seem to like it too!
                          Matt S, Cambs, UK
                          42" Pompeii
                          • asudavew
                            • Jul 2007
                            • 1880
                            #28
                            Re: Work so far
                            Originally posted by aureole
                            Keystone in- just!
                            Isn't that a great feeling!!?
                            That's the hard part..........but don't rush the curing fires. RESIST!
                            Congrats, it came out great.
                            You will be cooking in no time!
                            Dave
                            My thread:
                            My costs:
                            My pics:
                            • dbhansen
                              • Jun 2007
                              • 566
                              #29
                              Re: Work so far
                              Looks great, and it seems the cats like it too!
                              Picasa web album
                              Oven-building thread
                              • aureole
                                • Jun 2008
                                • 97
                                #30
                                Re: Work so far
                                Some pictures of the finished product, complete with chimney. Also - how to fix your oven from the inside!
                                Finally pulled the forms on the inside too (fibreboard tears more easily than it burns I found out). Inner brickwork is quite messy -that's the downside of using a wooden form. Hopefully it'll work just fine - started curing fires now
                                Matt S, Cambs, UK
                                42" Pompeii
