Re: Tims oven - early days!
And a couple more - I swapped the forms around the sides of the arch, poured concrete, let it set, then took the forms off. Then I got the cement board in place, I had to cut a little notch to fit it around the top of the arch. I stuck a strip of duct tape across the joins in the board. Once that was done, I laid a grid of rebar, using the ends of the vertical bars in the stand as spacers. I tied the bar together and now I'm almost ready to put up the forms!
