I cut most of the oven floor today using a 7" wet tile saw and an angle grinder with a masonry wheel. The cuts proved difficult b/c I had to constantly flip the bricks over to finish the cut. My cuts were not as precise as I had hoped. I ordered a 10" wet tile saw from Home Depot today and will use it to finish the rest of the cuts. I'm hoping that this will help with the rest of the brick cuts.
Oven floor
Tags: None
Re: Oven floor
I think you'll be happy with the saw - no more flipping things over and the wet saw will definately keep most of the dust down -
Becareful where you aim the saw - the water that comes off the cut carries brick dust and you can coat things pretty quickly! Part of my deck was stained with red brick clay while cutting the edges of my patio...
ChristoComment
Re: Oven floor
I'm thinking that I can cut a radius with the new saw b/c I was able to somewhat manipulate the brick on the 7" saw but turning the brick over made this maneauver difficult. I thought about getting a diamond blade for my circular saw but was worried about the amount of dust that would create. I'll have to rework some of the brick with my new saw as some of them don't have as a nice of a radius as I would have liked and the edges are not perpendicular to the floor.My WFO project: http://picasaweb.google.com/stevprin/WFOSmallPhotos#Comment
Re: Oven floor
It looks good Steve. The dust from dry cutting with a circular saw will eat up saws. I cut a bunch of pavers with a radial arm saw once and the dust was incredible and the saw was never the same after that and did not live long after that either (yeah, using a radial arm was stupid, I now know
If you do use a circular saw, I would suggest getting one just for that purpose, either a cheap one you can afford to trash or a purpose built one that is seal to take the punishment.
You will love the wet saw after doing the angle grinder thing, by the way
TravisTravisNTexasComment
Re: Oven floor
Thanks Travis. I have basically stopped all work until my wet saw arrives. It was just too hard to make a precise straight cut with the tools I had (I need more skill). The worst part was that I had to take off the guard on the 7" tile saw b/c the fire brick would not pass through. This caused the water/slurry to fly right into my face with every cut. Good thing I had my safety glasses on.My WFO project: http://picasaweb.google.com/stevprin/WFOSmallPhotos#Comment
