firing oven
  • roncut
    • Nov 2008
    • 27
    firing oven
    Has anyone had experience with firing up the oven in 32 degree weather? This is an outside oven.
  • PizzaPolice
    • Sep 2006
    • 338
    Re: firing oven
    Yep. I do it all the time. Noodle around the forum and you'll find a bunch of information.
    Basically, you want to start slowly to avoid thermal shock. After that, you're golden.
    • egalecki
      • Mar 2008
      • 1049
      Re: firing oven
      I've done it several times. If your wood's dry, it works fine. I didn't change anything about how I built my fire- just stacked it up and burned it top-down. I don't have any new cracks. The difference between even 20 degrees F and 50 or better isn't much when you consider that you're firing to 900 orr so degrees in the long run... If you're worried, just build a smaller fire to start and work your way up over the course of 1/2 hour or so.
      Elizabeth
      • roncut
        • Nov 2008
        • 27
        Re: firing oven
        thanks I will do that. I do want to have pizza over the holliday
