38" vault in tropical Australia
  • dmun
    • Jul 2005
    • 4218
    #16
    Re: 38" vault in tropical Australia
    I'm no structural engineer, but it seems to me that that method of "hanging" the support slab from a few pieces of rebar is extremely suspect. I've seen enough rusted-out rebar to think it's best deep buried in concrete.
    • Onefella
      • Nov 2008
      • 25
      #17
      The 16mm deformed bar that I'm using has a shear strength of 6.8 tonnes and there are 18 'attachment' points. The gap will reduce the shear capacity slightly, but by my calculations the slab could support 2-3 tonnes before the concrete itself would crack. Probably of more concern is the 'reo' bending and pulling out of my bond beam. But it's a tried-and-tested design, so Im pretty confident it will be ok.
      The exposed rebar in the 'gap' is painted with a good quality hi-temp black engine enamel. It will also be encased in vermicrete.
      I've attached a diagram of how the slab is arranged.
      • nissanneill
        • Apr 2007
        • 1886
        #18
        Onefella.
        tried and proven?
        Well I personally wouldn't have a bar of it! The 30mm of vermiculite is way insufficient insulation to stop the stored heat in your concrete from escaping and into your block work. the whole thing is upside down (and you don't need to use the cement sheet.
        The 16mm reinforcing bar will rust, no matter what you do or say, especially up in the tropics and more so with the continued heating and cooling. I don't care if you galvanise it, it will deteriorate and eventually fail.
        Mate, you are on your own with this one.
        That's my opinion expressed.
        I wish you well with your decission.
        Neill
        Neill’s Pompeiii #1
        Neill’s kitchen underway
        • Onefella
          • Nov 2008
          • 25
          #19
          Don't right me off just yet..
          I could lift the bottom sheet, remove the 'gap' formwork and have a pretty solid slab still.
          So would the cladding still rest on the hearth slab, or on some new insulated bottom layer?
          • nissanneill
            • Apr 2007
            • 1886
            #20
            Onefella,
            I have just drawn the construction as it is recommended and as how I did mine although it was built on a reinforced retaining wall.
            You can make the base the exact size of your oven or larger allowing a work area wherever you require.
            Neill
            Neill’s Pompeiii #1
            • Onefella
              • Nov 2008
              • 25
              #21
              Thanks for the advice nissanneill, this will take a major re-design. I'll have to consider my options. Cheers.
              • Dutchoven
                • Apr 2007
                • 931
                #22
                Let us know what you decide...we can still help... and yes the concrete cladding of a barrel vault oven should also rest on the insulating layer...I think if you flip the slabs around you might find it much simpler...you could pour your concrete with the sheet on the underside still pour everything in a big monolithic pour filling cores and all...then the vermicrete on top...in the end it might raise your oven's floor height up a bit...which again speaking from experience is not necessarily a bad thing
                All the best!
                Dutch
                • Onefella
                  • Nov 2008
                  • 25
                  #23
                  OK, it looks like I'm going to take everybody's advice and pour a solid hearth slab. I'll have to lift the bottom of my slab up 60mm. It should all work out ok.
                  • Onefella
                    • Nov 2008
                    • 25
                    #24
                    After much thought, I have decided to (more or less) stick to the original plan for my vault oven.
                    My slab has loose vermiculite under and around it now.
                    I'm starting the vault tomorrow.
                    • Onefella
                      • Nov 2008
                      • 25
                      #25
                      Here's the hearth with wall bricks ready for tomorrow.
                      I'm using a refactory mortar called Ryal Bond. It was a bitch to re-mix to a useable consistancy, but it sets like epoxy. Very strong.
                      • Onefella
                        • Nov 2008
                        • 25
                        #26
                        Walls up today.
                        It's been raining most of the day.. lovely and cool. Humiditity never dropped below 80% all day.
                        Start the entrance and wall bracing tomorrow.
                        • Onefella
                          • Nov 2008
                          • 25
                          #27
                          Entrance started. My bricklaying speed is a lot slower than I hoped.
                          • dmun
                            • Jul 2005
                            • 4218
                            #28
                            It's looking really good. I recommend going to photobucket to see these pictures full size.
                            Onefella - Photobucket - Video and Image Hosting
                            I love that bullnose tile you have in front of your entry.
                            • Onefella
                              • Nov 2008
                              • 25
                              #29
                              Thanks for your kind words mate. Very encouraging.
                              The bullnose tiles turned out ok. I wanted a ledge across the front of the entrance so I had somewhere to put my beer.
                              I'm starting the vault arches today and I'm a bit nervous about fluffing it.
                              • Dutchoven
                                • Apr 2007
                                • 931
                                #30
                                With your work so far you will have no problem...I thought I would fluff it both times...when building the oven at home(barrel vault) and with the dome at the restaurant...keep up the good work
                                Best
                                Dutch
