Larger Primavera Oven -- P70
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    This is very exciting. We just finished the first prototypes for a larger Primavera oven. It's the Primavera70, and it has a 28" round cooking floor and 6" landing. It's just like the Primavera60 (P70), but 4" larger. That's a lot of extra cooking space. Very cool.
    Still, the larger oven comes with a couple of things to think about.
    First, it weighs about 600lbs, so you need a quite a few friends and neighbors to pick it up (at least 6), or you can use a mechanical lift.
    Second, it does not come with a metal stand, and you will have to build a block stand for it. We don't feel good about having customers set such a large and heavy oven in a stand tray, and it will be much easier setting the P70 on top of a block stand and sliding it into place.
    Third, it is 41" wide, so you will have to make sure you can it through your fence or gate. It is not designed to go on its side during transportation.
    I think there are clear places where the Primavera60 and Primavera70 work best.
    If your space or access is limited, you don't want to build a stand, and you want to set your oven in place and start cooking, the P60 is perfect. It is also easier to take with you if you move.
    If you want a little more cooking space, are happy building a block stand and have access, the P70 is perfect.
    Of course if you want a larger oven and want to do a custom installation, the Casa, Artigiano and Premio series modular ovens start at 31" and go up from there.
    We will be testing the oven over the next few weeks.
    Let me know what you think! We're excited!
    Re: Larger Primavera Oven -- P70
    I'm thinking a piece of cast concrete drain pipe would be the ideal base for this:
    It's cheap, and made locally in most places since it's expensive to ship.
    • ERASMO
      • Oct 2008
      • 85
      Oven looks great. Any idea on the price in comparison to the P60. Can I get on the list for prototype testing??
      • james
        Brick Oven Merchant
        • Mar 2005
        • 4648
        Hi Carl,
        Good idea. Let's talk about this off line. I'll contact you.
        The price will be somewhat higher than the P60. Larger oven, but no stand.
        • berryst
          • Jun 2008
          • 184
          How come there's a tonka truck in the photo?
          sigpic
          • Frances
            • Aug 2007
            • 2186
            Its to give you a sense of scale - and personally I think those concrete pipes might be a tad big for the oven...
            • james
              Brick Oven Merchant
              • Mar 2005
              • 4648
              Great minds Dmun,
              When I installed my first modular oven in Italy, I saw a demo oven at a building supply store set on a round concrete drain pipe. I thought wow, this will be easy, and I drove to our nearby store. Well, those guys weigh a ton -- I remember not being able to lift one side by myself. Still, I was on my own, and it wouldn't fit in my Passat station wagon anyway. We need to look up how much they weigh.
              The good part was that I found those hollow terracotta beams that you can't buy in the U.S. -- and they fit in the car.
                Yes, those are big suckers (I don't think that's a tonka truck in the background) but it's what came up on the first page of google image search. They come in lots of sizes, and are heavy, but you'll need riggers (or good engineering) to get the oven in place, and the same skills could be used with the pipe. And unlike the oven, you can roll the pipe.
                I've never understood, James, why you don't import those terra cotta lintels. I'm sure lots of folks would jump at the chance not to pour a second slab. They must come from the same general part of the world, if not the same furnaces, as the oven components.
                • james
                  Brick Oven Merchant
                  • Mar 2005
                  • 4648
                  Hey Dmun,
                  I've never been able to picture shipping such a low-tech item such long distances. In a sense, it only replaces the Hardiback and forms, as you still have to pour a concrete slab on top of it. Still, they're a great idea.
                  Here is a new photo of the P70 next to the P60 in my front garden. You can use Lizzy for a sense of perspective. :-) I think you can see that it is fundamentally the same, but larger.
                    My mistake - I thought they were strong enough to support the oven by themselves, much like our cast lintels are. I thought that this oven:
                    had only the terra-cotta lintels under the insulation. You're right, it doesn't make sense if they have to cast a slab on top.
                    • james
                      Brick Oven Merchant
                      • Mar 2005
                      • 4648
                      Memories! That oven still stands in the garden of that great house in San Gimignano. You can see it over the fence when you are in the playground behind Via Quercecchio, just off main piazza.
                      This is challenging my memory. I might have set the oven on sand directly on the beams, but I wouldn't trust that with a long-term install. My second oven definitely had a thin concrete and wire layer.
                      Thanks for finding that Dmun.
                      • tadavis
                        • Apr 2009
                        • 1
                        Hey James!
                        My first post on this forum, however, I can't express how much I've appreciated this site as I have begun my foray into pizza making and bread baking.
                        As someone who doesn't have the time, patience, or skill to build an oven, and also as someone who may be relocating in the near future, I find the Primavera ovens a very attractive option. However, the 60 is slightly small for me, as I would really be able to take advantage of the extra room in the 70. Also, my fiance is currently apprenticing with a very reputable catering company in our area, and would love to use this oven to prepare/create new recipes and menu items.
                        This being the case, I was hoping to get any updates you may have on this new oven? How is it at holding heat longer compared to the 60 (due to its increase in mass)? Also, I had previously seen a post about a prototype list, if there is any chance to still get on this that would be great (and I could promise excellent updates/feedback/photos, do mostly to my fiance's culinary abilities ).
                        Thanks, and look forward to hearing more!
                        Tyler
                        • Fish Whisperer
                          • Sep 2012
                          • 26
                          Just got my new P70 installed in the outdoor kitchen. Great little oven !!! Thanks !!
                          • whodatoven
                            • Oct 2010
                            • 26
                            FW, looks great, enjoy, I got P70 too. Is it the photo distortion or what that your P70 looks "flat" in the photo?
                            • Fish Whisperer
                              • Sep 2012
                              • 26
                              No that's how it looks. It does look a bit flatter than the catalog pics now that you mention it.
