Adobe Pompeii
  • Adobe Pompeii
    It's almost done :-)
    Chris
    Re: Adobe Pompeii
      Re: Adobe Pompeii
        Re: Adobe Pompeii
        Hey Chris,
        This is an interesting looking oven!
        What have you used to build your brick? Is it a local clay? and what all did you mix in with the base material?
        Are you planning to insulate the dome?
        I will be interested to see your results! If the material holds up to the heat of the fire, it should work beautifully.
        Keep us posted with progress and pictures!
        JED
          Re: Adobe Pompeii
          Yeah, what he said...
          I don't know why, I love my brick oven madly, but I'm just also fascinated with clay ovens. So do keep us posted, it looks great!
            Re: Adobe Pompeii
            Oh hey, this thread belongs oven in alternative ovens, it'll just get lost here.
            ...right James?
              Re: Adobe Pompeii
              The adobe was a local dirt/clay I used to make some bike jumps in the yard, straw and water. I let the bricks dry about a week.
              The mortar was about 20 parts adobe to 1 part concrete. We let the initial shell dry about a week, then small fires leading up to the big one pictured above (the food was delicious!).
              Then layers of adobe slapped on and smoothed out by hand. I moved the chimney back, with the thought that the dome might heat faster having hot air moving on both sides. The top is about 9" thick, the sides are about 6". I can stand on top of the dome, so I think that's good.
              It's pretty much shaped out now, just need to wait another week or so, then small fires and such. Weather is looking great, high 70's for 5 days, so hopefully it will cure fast. I'm hungry.
              After a few large fires, I'm going to seal it with a 1 part portland cement to 3 parts screened soil mix. It can always be repaired/kept up with the same mix.
              I've never done this before, it may collapse in a shower of sparks, but it's been really fun, and the little bits of food have been wonderful.
              Only downside of the project was needing another bag of concrete, bringing it into major cost-overrun, from the budgeted $3.50 up to $7.
              I've got an IRT, I'll get some temps and pictures when we get going This forum has been great, as well as the Forno Bravo pdf. Thanks guys!
              Chris
                Re: Adobe Pompeii
                Two other things.. the floor of the oven is fire brick that is floating from the rest of the structure. The base is the old well for the property.
                Chris
                  Re: Adobe Pompeii
                  looking forward to seeing the next set of pictures GlassKitchen. Nice Work.
                    Re: Adobe Pompeii
                    And expect a bit of grief from the Master of Operations at your home for a 100% cost overrun!
                    I solved the problem by not creating a budget, however, I did spend substantially more on the finished product, and I bet the pizza from either oven is just as fine!
                    Good work!
                    JED
                      Re: Adobe Pompeii
                      We decided to go for it, it seemed to work. It really gave us a 60-90 second pizza, it exceeded all expectations. No cracking or collapse
                      The top of the dome got up to 1050 and settled around 1000 throughout the cooking. The sides were about 850, and the floor was around 700-800. The exterior was 140 at its hottest point. About 4 hours after the last piece of wood the dome was about 700, sides about 650, with a nice bed of coals.
                      We didn't make bread, I'll never make that mistake again. We could have easily done some roasting after pizza and then baked at least one batch of bread.
                      Next morning the oven floor was around 100, sides about 125, dome about 160. The inside of the dome was fine, no cracking, everything made a nice 'tink' sound when tapped, nothing fell. I am amazed.
                      Thanks again for the forum!
                      Chris
                        Re: Adobe Pompeii
                        Chris
                          Re: Adobe Pompeii
                          Considering the horrific cost, nice looking oven.
                          J W
                            Re: Adobe Pompeii
                            This is very cool. You did a really nice job on it!
                            Elizabeth
                              Re: Adobe Pompeii
                              Just an update.. we are using this thing almost every night. Grilling, smoking, beef, fish, had a great pork BBQ last night, chicken tonight, roasted and grilled vegetables. It's so much fun to have the range of heat, you could never cook like this on a conventional oven.
                              Thank you so much for this forum, and all of you that wrote descriptions and took pictures. It's the best resource in the world. We really appreciate it, never would have happened without all you good folk
                              Chris, Lissa, and Ari
