(M) This shows the new sheet metal roofing tiles from Decra. Also visible is the custom made ceramic chimney cap. The stucco just below the lowest side covers and fills a void in the sheet metal tile where I notched it to accept the ceramic cap. I didn't need as much as shows but tried to shape it to approximate the "tiles".
(M) This shows the custom built peel and ash shovel, both of stainless steel to remain out doors. The peel works fine. The ash shovel is fine for pushing wood and ashes to the side but it's straight sides do not work well for removing ash from the circular inside. Better get one like James sells through Forno Bravo.
(M) The straight piece on the left is an improvised hook I made from a scrap of left over sheet metal stud. I bent about 2 inches up from the far end. It actually works fairly well but looks like what it is, sCRAP.
I'm hoping that a windy day precipitated smoke exiting in front of the oven rather than up the chimney but I'm afraid that I made my flue too small. Also, the approach (throat? manifold?) should have been sloped like a funnel. If you haven't built yours yet don't bother including a damper either. Since the chimney is outside the dome there should be no reason to ever need to close it. That was work done for no reason. As CanuckJim would say, "Strong like bull, smart like streetcar", except I'm not strong. Or, as Aesop would say:
