Re: 36" in Seattle
If the 2.2lbs bag you bought was red than its not the same. The one in the red bag has a higher protein content than the blue "pizzeria" bag.
but guests can be picky
) then put the door back on to let the heat re-organize after cooling it down with the wet mop. At some point, after resting, all 3-4 temp readings are closely equalized at the bread temps you want. Or what you did sounded as successful as anyone gets. It's all fun and you learn as you go.
