Re: 36" Tall Man's Oven Build
I may end up with an eighty four inch chimney. That would put me 36" above the top of my planned roof. I've heard 36" above the highest point of the roof is the minimum desired clearance to make sure there's no interference with the draft pull.
Thanks for the tip on heating the chimney to create pull pdiff, I'm going to remember that one.
Darius
Stack flow can be sensitive to ambient air temps. If the stack is cold, it will resist hot air trying to rise within it. The old fireplace flue trick of blowing out the stack with hot air might help. As you light the oven fire, you could try sticking a newspaper "torch" directly under the stack to initiate and facilitate the flow. This may be even more true with a tall stack.
my chimney is going to be really tall, so maybe it'll act as a vaccum and suck the smoke right out.
Mine is 5" deep by 7 1/2" wide. Sounds like I may get a little smoke out the front too. However, my chimney is going to be really tall, so maybe it'll act as a vaccum and suck the smoke right out. Either way, I'm not going to worry too much about it. Thanks Mark!
Darius
Hey King,
Its about 3 1/2 wide x 9 long.. once the fire gets going its fine... i was thinking of cutting it larger with the diamond blade, i could probably get another inch on each side giving me 5 1/2 but i dont want to shut the oven down if i have a problem and have to rebuild the arch and chimney... I think the black on the front of the oven adds charm
Mark
Mark, how big is your chimney opening in the arch?
hey morgans,
I used fire brick for my chimney because I had enough left for it, I mortared it directly to the arch using heatstop 50 ... works well once it gets going, Only mistake I made was not making the chimney hole big enough in the arch.. I did go two ros of brick higher than what you see in the pic.
cheers
MarkLast edited by ThisOldGarageNJ; 08-16-2010, 05:47 PM.
It depends on what kind of chimney you're going to use. We used 3 feet of 6" Simpson Duratech (UL 103HT). We used an anchor plate by Simpson that is made for this type of chimney. We drilled holes into our brick and tapped-in lead anchors (dollies) and just screwed the anchor plate down. The chimney pipe just sort of screws on to the anchor plate (twist-lock). Just that simple.
I'm partial to bourbon, but vodka and tonic is good too! ching-ching!
'Morgans
Thanks for sharing the moment with me guys! I'll go ahead and remove the forms tomorrow then. Thanks for the tip Ken. With my long arms I might be able to do the last inside patch work from the outside without having to stick my upper body inside, especially since the dome is so low.
I'm not too worried about building my chimney transition out of brick, the only thing I'm unsure about is how to attach the chimney to the top of the brick. If it's in the fb manual, then I couldn't find it. How did you guys attach your chimney?
Oh BTW, it's vodka and tonic!
Thanks,
DariusLast edited by KINGRIUS; 10-05-2009, 08:34 PM.
Hey Darius,
Congratulations..... A job well done, Its a Milestone as well as a keystone
Many Happy Pizza's,
Mark
Dude, that's awesome. I feel your joy!
You don't have to wait to remove the forms, unless you fear it will result in pushing upward on the bricks that are starting to set. Theoretically, the structure is supporting itself now. The last outer archway I made, I removed the forms immediately after I tapped-in the keystone. Just makes cleaning the fresh mortar off the bricks much easier.
So, relax tonight, plot your next moves, and have a well deserved drink of your choice!
Good work!
Ken
I'm there!!!
I closed up the dome today!
Originally posted by vintagemx0 View PostYou're going to have a mile-wide grin on your face when you put that keystone in the top and it's officially closed-up.
Here's a keystone for a keyhole-
I'm going to wait a couple days before I remove the forms, but I'll start the chimney transition tomorrow.
Darius5 Photos
nice cutting king... keep going your almost there
I was able to get the new forms back out of the oven to do as much patching from the hole in the top as possible before I close it up. (thanks again for the advice Ken!)
I worked on it for about 3 hours today and all I did was cut bricks. Yesterday I cut and set a chain. I have about 4 to 5 bricks to cut before I'll mortar this chain in place. Why is it I'm starting to get the hang of this when I'm almost done?!2 Photos
Originally posted by vintagemx0 View PostOne peice of advice would be to take those forms out and climb in there now and patch as much as you can to take advantage of the opening at the top of the dome letting in good light. Lighting is an issue in there when it's closed and it's hard to manage a flashlight with your body in there. If all is done except the last few rows, it won't be as bad.
Originally posted by pizza bob View PostI'm 6' 6" tall and have the same concern about cleaning-up the dome!
Thanks for the advice and encouragement gize, I'm going to see what I can do about getting these forms out without destroying them.
Darius
