I've been lurking / thinking for a while but finally got started in earnest on the oven this week. I poured a slab a while ago and got the stand finished yesterday.
You can see I had to taper the blocks as the slab had a lot of fall in it, but everything came out right. A good introduction to masonry for me.
I've got upright #4 rebars, two per side, and I'll bend these over into my bridge slab. One other thing I modified is the height of the lower opening, three blocks seemed too tight, so I'm just going to form the bridge slab to go over that opening.
I'm planning to do the bridge slab at about 4" of structural concrete, and then make a rectangular 'frame' out of 2" of structural concrete. In the middle of the frame underneath the oven floor I am planning to put the 2" insulating foam board I've seen mentioned here. Any thoughts / comments / suggestions on that approach are welcome.
Thanks for all the ideas and inspiration so far. Here are the obligatory block stand photos.
I'm very much just winging it as I go, leaning on the experience of everyone here to get me by.
