Re: Wrong dimensions - Help!!
Hi Peter, no problem with your question (this is theoretical work for me anyway, as I haven't done a mod like that myself).
Yes, the metal ring would provide the same support. Then again I was talking about a new slab. As you don't plan to pour one to end at the same height, you must however have solid, insulating, non-removable forms, as fiber board is NOT a load bearing structure. Just a outer ring won't do it. You need a sort of metal sheet floor I guess, something to support the weight of bricks and logs.
Your outer ring will have to go in in pieces though, as well as your forms....
