Hello to all ,
I'm new to the forum such a amazing site so much information.I'm in the process of building my 1st pizza oven so excited ,but nervous I'm actually building it on top of an existing outdoor fireplace.I already have the pad poured ready for the fire brick's, it's 'about 52"-1/2w x 56"l 5'thick.I purchased the fire brick 9 x 4-1/2 x 2-1/2 and cut them in half, I also purchased 2'thermafiber insulation board k-fac19 for the base.The oven will be 36'inside dia. the door will be 10'high x 18 wide and the ceiling height is 16" which give's a door to ceiling height ratio of 62.5%. I still have to purchase the insulation for around the dome which will be 3" and then 2 more inches of refractory mortar.I have a couple of question regarding the chimney,flue and,vent.I want to use a 6" chimney but,don't know how tall to make it, 24"or 36". How big should the vent be? and,how much room do I need from the door to the outside of the arch way will one brick length do?.I get a little discourage sometime ,I'm a pretty good hands on guy just want to build it right, don't care how long it take .Am I headed in the right direction? Thanks to all Bruno
