Combo ovens
  • Pfurn
    • Dec 2012
    • 4
    Combo ovens
    Has anyone ever built a continuous fired oven/ fireplace that can burn and cook for 12-16 hours? I'm looking to have a fireplace on the bottom and an oven on top. The fireplace would be the heat source for the oven.
    • 2848
    Re: Combo ovens
    Gudday
    I think you need to understand how a wfo works. Get youself a copy of the plans and there is section on how them work. Basically you'll find they have an external chimney to work correctly... adding a fireplace which requires an internal chimney in not compatable.
    regards Dave
    • TropicalCoasting
      • Dec 2011
      • 408
      Re: Combo ovens
      might want to check this thread out
      • Pfurn
        • Dec 2012
        • 4
        Re: Combo ovens
        Thank you both for this info and the link. I know I have to do much more research on this but the wheels are turning. I am a general contractor from ,New Jersey, USA, and have many resources for materials, but a little lacking on design. I have started drawings for this and have a basic design in mind. I will post them soon.
        • Tscarborough
          • Oct 2009
          • 3341
          Re: Combo ovens
          Please draw them out. I have not seen, or been able to figure out, a practical way to build a fireplace/oven that share a common flue. Keep in mind that an oven built to the Forno Bravo plans and specifications can be cooked in for for 24-48 hours after an initial firing.
          • Laurentius
            • Nov 2010
            • 923
            Re: Combo ovens
            Pfurn,
            Please keep scientific principles of energy and energy management in mind with your design, then you will have no problems.
