Cutting roll of insulation to fit dome
  • Cutting roll of insulation to fit dome
    The insulation roll is 24 inches wide. How to cut it for
    good coverage and minimum waste? I have not solved
    the question of how to make triangles fit? Just slap dash
    draping and overlapping seems crude and wasteful. Any
    ideas will be appreciated. I could not find much information
    searching threads and photos. Thanks. Careme in NC
    Re: Cutting roll of insulation to fit dome
    C,
    You may want to post your question under the construction thread, will see more response there. Here is a pic of my CF and where I cut (V's for the curvature and Squares where the blanket seams are butted together). My CF was 48" wide and I cut 32" x 48" squares and installed horizontal. I took alot of care in cutting and fitting since I am doing an igloo and wanted to maintain the dome shape. If you do an enclosure then the fitting is not quite a critical. Can't emphasize enough to insulate, insulate, insulate.
      I found cutting equilateral triangle the best method, just lay them head to toe.
        I cut about 4 or 5 triangles for my first oven, which went from the base to the top, but found I had to belly the sides out in a curve so they would fit the curve of the dome. Straight triangles give you gaps between them when bent around the sphere.
          I draped the blanket over/around the dome, then cut the wrinkles with a scissors-style hedge clipper - make a single cut and overlap the edges, or two cuts, remove the wedge, and butt the edges. Overlap the seams on successive layers.
