I have purchased a Premio2G100 kit, and have completed the slab and the concrete block stand. My question is should I float the hearth by using the full coverage of the concrete blocks with the 1/2 inch Backer Board, or can I omit the Backer Board and fill the unfilled concrete block chambers with concrete and rebar when I pour the hearth? I believe this will make a more structurally strong unit, but I don't want to create heat transfer problems from the hearth to the stand, resulting in long term structural damage. I have read and received mixed opinions and responses to this question. I am stopped on my construction until I resolve this issue.
Thank you,
RDL - Woodlands, Tx
Thank you,
RDL - Woodlands, Tx
