We are starting a project this week for a custom built oven that is designed to have 2 individual openings/ Chimneys - see attached image showing planned footprint for the planned layout. I have built an oven before but with a single opening and a clean out hatch at the back but this oven is larger and more complex so before casting everything in concrete ( the footprint of the supporting slab only ) it would be good with some opinions about whether this design will work as planned:
* Dual opening, meaning access from two sides to the oven
* Oven is 3/4 of a circle as it will have to be built around a structural concrete corner on site
* Inside net diameter inside the dome will be 175 cm or 68 inches measured across, with 1/4 of the circle missing.
* It should be possible to place 2 pcs up to 16" pizza's inside one of the cooking areas and up to 3 pcs 10" pizza's in the second cooking area - these can be seen on the attached picture as round brown circles laid out on the floor at the location they would be inside the finished oven
* The plan is to have one large central fire inside the oven that will provide heat for the dome and out to both sides. The area for this fire would be 65cm/ 24-25" in width and around 75cm/ 30" in length and can be seen on the picture as a built up area with firebrick in the middle of the oven
* In the ideal situation there will be installed a clean out tray in in the lineup with the area where the wood is burning for easier clean out. This hatch will be fully closed when the oven is in use and only minimum heat loss through this area. This is the third opening in the oven as seen on the picture, placed in between the 2 regular openings used for cooking.
* The plan is for the 2 cooking entrances to be without a hatch so that the openings are providing easy access and direct view to the flames inside. It will however be built in such a way that 2 hatches ( similar to the one seen placed at the clean out hatch ) can be installed later in case we encounter problems heating up the oven to a high enough temperature due to heat loss through 2 unsealed hatches - this is planned like this so that the oven can be saved without breaking it down and rebuilding it if the design fails.
* The oven should ideally be able to bake a pizza in 3-8 minutes depending on how high a temperature we heat it to, if super hot and busy we will have 2 staff, one at each opening, if less busy we may just cook on one side with one staff
* There will be 2 chimneys on the oven ( placed just behind the 2 openings ) with an approximate inner pipe diameter of 150mm/ 6" - these 2 chimneys will merge into one above the oven and lead out of the building in a larger diameter pipe after the merge. On the picture these chimneys are placed standing on the arches, they will be located right after the arch in the final built oven so roughly 150mm/ 6" further back than now.
I am looking for specific advice as to whether you believe, ideally based on a fair bit of experience, that the design will work, be able to reach high cooking temperatures and whether the 2 chimney, 2 opening hatches will work in terms of air flow, heat loss etc.
The layout shown is done on the floor in the area where the oven will be but all this will be raised up onto a slab poured 30" higher, need to make final decisions about the size, shape and locations for hatches and clean outs over the next few days.
Advice appreciated as crucial decisions will have to be made this week. Please be constructive - will follow up as project will progress - got 6 weeks to targeted first use and hope to post pictures of the oven in use by mid May.
