Hi guys,
  • Hi guys,
    Hi people
    Im new with this idea of ovens I wish can learn a lot.
    Walt
    Re: Hi guys,
    ive only just got here and its information overload so I am sure you are in the right place
      Re: Hi guys,
      Welcome Walt and Turkey to the Forum
        Re: Hi guys,
        Waltiti, what part of Florida are you in, I'm in south florida, actually Cooper City
          Re: Hi guys,
          South florida too, but 2hs from cooper city.Why?
            Re: Hi guys,
            Welcome, there are many talented and generous builders on this site. I recommend that you look over a lot of the veteran as well as some of the newer builders as they have a wealth on knowlege. Great thing about living in South FL is that you can build year round. I started mine in Oct of 08 and finished around the following Jan.
            My WFO project: http://picasaweb.google.com/stevprin/WFOSmallPhotos#
              Re: Hi guys,
              Thanks guys for the welcome, actually I make a question like a couple of days and I think anybody see that, so I copy and paste here, mave is more visible here. Thanks
              Hi I need some help
              I want to make concave walls around 3'x3'x2" 3'x6'x2" with a pre-cast framework concrete and Leca to make insulated lightweight concrete.
              I read the mix is ,1 portland, 3 sand and 2 leca, and rebar of 3/8 - 1/4, ( thick rebar make cracks ). The wall will be 2" to 2 1/2" thick. You think is this correct.? Is better add 1 lime.?
              Also, I can replace Leca for Perlite or Vemiculite to get the same results, lightweight insulated concrete.
              Inside the walls I will apply a layer af refractory cement ( mortar type N + fireclay) and over this layer the firebricks of 1 1/2 inch thick.
              I thinking do something I can move.
              Thanks for all the help.
              Walt.
                Re: Hi guys,
                Walt,
                I think what you are proposing is a rectangular oven 3'X6' with a 3' height with 2" thick walls. That is much bigger than anything anybody on this site is building for home use. It sounds like you are planning on refractory cement for the inside of the oven, then a layer of insulation with rebar in it, and fire bricks on the outside. Your insulating layer needs to be on the outside of the oven, then either firebricks or refractory cement for the inside of the oven, but not both. My recommendation is to download the free Pompeii plans, read them thoroughly then adapt the concepts to a rectangular oven if that is what you are intent on. Good luck.
                Eric
                  Re: Hi guys,
                  mmm no...
                  Im not explain well my complete idea becouse that not was the question, but, if you divide in 4 a half oval/circle , the sizes of each part Of the dome, " I want to do " , will be around 3 foot from one edge to another edge, and I will do that, with a pre-cast/framework/molds and mortar with Leca.
                  The outside of this parts I want to do it with mortar cement Type N plus Leca, that make each pice light , also on the inside side of each part I will apply a coat / layer of refractory mortar ( type N plus fireclay) and thin fire bricks on this coat.
                  I already download the free manual. Also already have the firebricks, fireclay and fiber to reinfore the mortar.
                  But im asking about the mortar proportion of the Lightweight concrete, it is made with Leca, and also the leca is an insulator (%50 more insulation).
                  For the heart of the oven I not have problem, only is with the dome, I want to know, or some advices, if this idea will work, and also the proportions of the Leca I need will use, I think is 2. Also if I replace the leca for perlite or vermiculite I will have the same results ( lightweight and insulation).
                  Thanks again for the help
                  Walt
