Re: please help with my dome oven
Les, Your oven is beautiful! I like the way you have all the peels hooked on the side of the brick. I saw that you put vermiculite. Did that go on after the insulation blanket? Tell me if I have the right order of things. After the dome is made you can put an inch of high heat mortar around the dome. Next is the 3 inch insulation blanket. Then there is the chicken wire. Now, what goes on top of the wire? Thanks...Mina
