Help with insulating the base
  • hmc3142
    • May 2010
    • 29
    hi everyone, can someone tell me how I insulate the base of what a round wfo will be sitting on? What order and how many inches. For instance, from the bottom up, you put cement, then what is next layer, then next , then next until you lay your firebrick oven floor. Thanks so, so much!
  • fxpose
    • Jul 2009
    • 942
    Re: Help with insulating the base
    Here ya go:
    George
    My 34" WFO build
      In brief, the oven rests on a reinforced concrete slab, four inches or so. On top of this is your insulation, either four inches of vermiculite concrete, or two inches of refractory insulation board. If using vermiculite, a leveling mixture of sand and fireclay is put down, then the firebrick floor. Most everyone lays the firebrick flat, for two and a quarter inches.
      • hmc3142
        • May 2010
        • 29
        Hi Dmun...Thanks for the great advice. I want to insulate well and not skimp on any conditions. Can you please tell me how you would insulate the firebrick dome in the order that it goes and how many inches of the insulation. Thanks so much!
        • Eric Pfeifer
          • Oct 2009
          • 106
          I insulated my base with one inch of percrete on top of the structural slab, plus two inches of FB board. A full hot burn at equilibrium on my oven does not get the opposite side of the structural slab more than about 100 or so degrees--basically a hot Minnesota summer.
          • hmc3142
            • May 2010
            • 29
            Hi Eric,
            Is percrete perlite and concrete? FB board is what kind of board? Thanks so much!
              Perlite (or vermiculite) and portland cement. The perlite is a lightweight aggregate, not a concrete additive.
              Refractory mineral fiber board. I used insblock19. There are lots of brands, and a more expensive alternative, calcium-silicate (cal-sil) board.
              • Eric Pfeifer
                • Oct 2009
                • 106
                Dmun beat me to it! Best wishes on your build!
                • hmc3142
                  • May 2010
                  • 29
                  Thanks everyone for all of your great help! Mina
