Hi there.
I come from a land down under (as the song goes), and after much procrastination, I am planning to build an 1100mm (43.3") Pompeii style brick oven. To date, I have spent many fruitful hours gaining valuable information and ideas from forum contributors, as well as reading Russell Jeavons? book "Your Brick Oven" (The Bread Builders is on its way across the Pacific).
1) I note that the materials list for a 42" oven specifies 100 bricks for the floor - is this for bricks laid on edge or on the flat?
2) For the dome, 180 bricks are specified - does this refer to the total number of whole bricks @ 9"x4"x3" that need to be purchased, or is it the number of half bricks which actually form the dome? I assume the former, but wanted to check before ordering.
Thanks for setting up such a fantastic resource - I only hope I can contribute to it as this project progresses.
Cheers, Paul.
Cheers, Paul.
I would check a little further, and go for higher duty bricks if you have to.
