About 15 years ago I built an oven using 'glacier-till' + cement + cheap fire-clay (from pottery supply). Then used too much cement on the out side, (seperated by aluminum foil that collapsed so that there was no air space between). it worked, but the dome was to high to cook well. And the cement swelled up and seperated from the base.
So this time I want to forget the problems of clay and go for brick. the question is "how many medium duty bricks would I need for an oven that can hold about 10 loaves?" And can I use 'fire clay' from a pottery supply for the morter?
And can I use only one layer of brick, with some thing on the out side to make it water proof?
There is so much info to absorb, I maybe here for a while.
