Re: Intro from California
Bob said it right:
I looked at 2 local (1 commercial) refratcory pizza/bread oven manufacturers in the Los Angeles area and then FB's Casa etc.. and purely by accident clicked on the FORUM link (something I usually avoid on the interwebs) and to say I'm happy with the results is truly an understatement.
When I figured that both (pre-cast and homemade-pompeii) require a footing, a block base, a level floor, sand for leveling, piecing blocks or sections together, high-temp mortar, insulation, wiring to hold the insulation, a housing of some sort....... that's when we said let's just build our own, we have to do all this same work anyway, how hard could cutting firebrick in half be?
If you really want the extended heat retention (but longer heat up/wood use) you can put the floor bricks on edge (instead of flat) like an A. Scott oven and add a little extra dome "claddiing" with high-heat mortar to the outside of the dome and insulate the heck out of it and you'll have a custom bread oven as fine and possibly better than anything you can buy.
If you have the time, I recommend the build it yourself experience, whether you make a pompeii round or barrel arch style (but not the A. Scott type barrel). Pompeii-round is well documented on this forum but both are easy (with our help of course
Good luck with your decission.,
-dino
Bob said it right:
Originally posted by azpizzanut
View Post
-dino
