Well a big HI to all out there that have built, are building, thinking of building or even just dreaming of a WFO......
thanks for all the posts i have read and stayed up many hrs instead of sleeping hehehehe.... A big hi to my mate dave that started me on this path by seeing his WFO he has made 2 now....
So I have came to the conclusion I only want to build 1 .... just have it so it can be moved it needed(mindyou i will need a mobile crane to pick it up hehe)
I have started the process by
# placing down 100mm C channel down and levelling it all then digging down another 50mmso i have a good 6" of slab... ( mymates 1st WFO had 4" slab and I remember him telling me once he wished it was 6" ) so 6" it is straight up
#then went to town 120Km away and picked up 2cubic mtrs of a Sand/Gravel mix, 24 bags of Cement, 2 full sheets of Reinforcing mesh, 8 x 12mm reo Bar, 60 Full channel Blocks, 6 hlf blocks.... with all that it was a slow trip home hehe the truck was FULL
# I bought 2 pallets of second hand Fire bricks from a Brickworks that pulled down their Brick Kiln and sold up everything (as the land is worth a fortune that close to town ) .... So i have roughly just over 600 Full fire bricks to use.
# I have layed down a 2200mm x 2200mm x 150mm slab The slab has reo in it as well as some old loop mesh fencing looping down for extra strenght, I also have Reo Bar bent and tied to the mesh to come up under the slab reo (for lifting if ever needed) and extending 900mm up in the air...
#I think i will go with the Roman Hall shape rather then the Dome shape of http://www.fornobravo.com/forum/f51/...art-14844.html Even though I think he's done an awesome job... We also have lots of people to feed... 7 people in just our household plus when Nana and Grandad come for dinner makes 9... and thats wthout any othersturning up like they do... We can have a normal crowd of up to 20 people so bigger is better...
# so i have almost laid the first layer of support blocks and already i have worked out I need 4 layers of Blocks rather then 3 so next time im in town must remember another 15 Full channel blocks
# I will be cutting all bricks to correct angles by using a CAD program i use for my laser cutters..(shame I cant put them in my laser cutter to cut them
so that way i use less Mortar and hopefully last longer...
BUT first things first To FINISH the BASE ...
