Hey guys,
Just found this site...........Wow.........What a wealth of knowledge! Really looking forward to learning as I progress with my 1st oven
I have wanted to do this oven since I built the house in 2004........Better late than never I guess
I started the oven a couple weeks ago and now I am to the point where I really need some advice, sooooo many questions especially about insulations, refractory mortars, differential thermal expantion between materials
I guess I am building a semi dome or arched oven with a straight wall in the back. A friend had purchased a picture tutorial from one of the (other) websites and I am using that as a guide but there is no description of materials
I built my base out of tube steel 2.5"x2.5"x 1/4" on a 8" concrete pad.
2" rigid insul is fit between the framing members of the floor and the cross tubes are filled with pour-rock. The cantilevered arms are to support some 1" thick granite countertop from a kitchen renovation. I am ready to pour the floor next.
My biggest concerns are;
1.) I purchased perlite wall insulation to mix into the concrete. As far as size it is almost like course sand. Should I use larger aggregate insul ? I noticed some pre-cast oven kits at the mason supply had larger BB sized aggregate exposed.
The perlite was all I could find locally but I will order something if need be.
2.) Do you use insul through the entire slab or only mix a batch to do a spot say 2" thick just under the cooking area floor then fill in over it with regular concrete? Does the insul weaken the concrete?
3.) And finally, can you have too much re-bar in the pour?
I have a grid now of 3/4" bar. My concern was the bar might heat and cool at a different rate then the concrete working against each other. Maybe mesh is a better option?
Thanks in advance for any replies,
Nate
Nate
