Primavera on my deck
  • DavisI
    • May 2008
    • 10
    Hi from the Chicago suburbs,
    I am preparing my raised deck for a Primavera 70. I will be tiling a large area to hold the oven, have studied all the install stories here and am pretty much ready to go. Has anyone tiled their deck for their oven? I am interested in any pictures to see how it came out, anything I should know going in.
  • trish
    • Sep 2012
    • 2
    Re: Primavera on my deck
    I too have a primavera on my deck. I used to have it on a brick paver patio and recently moved it to a deck. I do not have tiling under it because I was concerned both about weight and about tiles cracking and the possibility of embers getting hidden and then fed with oxygen from underneath. Instead I was considering using fire retardant rugs like those available for hearths and then just picking them up & putting away when the oven was not in use.
    I have another question for you: are you considering using a spark arrester for you chimney, & what about the door?
    Trish
    • DavisI
      • May 2008
      • 10
      Hi,
      I am tiling a 50 sq ft corner of my deck, crosswise to the prevailing winds. Any sparks should go out into our 3 acre back yard, so no worries about neighbors. I hadn't thought about a spark arrestor, but I will now, because you can't be too careful, thanks. As soon as the weather permits here in the midwest, I'll be getting at it.
      I'll be using this TI-PROBOARD? Lets You Tile Anywhere as underlayment for the tile, I am not worried about weight or tile cracking. I (over)built the deck myself and will be adding some strategic reinforcement, but really, it won't be more weight than a few large guys standing around.
      As for the oven door, I am replacing my wooden railings with wrought iron and will have a hanger on the railing for the door.
      Still looking for any pictures.
      davis
