New Guy needs help
  • TheBigC
    • May 2013
    • 5
    New Guy needs help
    Greetings all,
    I am building a 42" Pompeii. I poured the insulating layer of concrete. I followed the instructions mixing 5 to 1 vermiculite to Portland cement. Thoroughly mixed it dry, mixed it wet and poured. I screed it off. It has been poured for 4 days now. It set up well and is very firm BUT the surface has some give if I press my finger on it. Is that normal or have I done this wrong?
    Advice please! Thanks in advance.
  • Reg
    • Apr 2013
    • 1
    Re: New Guy needs help
    BigC,
    This is Reg, I just poured my insulating layer of concrete today and I'm experiencing the same level of uncertainty: that layer gives a little when pressed with finger. What did you finally discover after after your pour?
    • TheBigC
      • May 2013
      • 5
      Hi Reg,
      I found out the the finished insulation layer should feel a bit like a cork. It give a bit when you press on it. It's edges also flake of and the top is easily gouged or marked. I used the mud (sand and fire clay) to even out the marks and lay a level floor. It has high compression strength. It's wired but it sounds like you are doing it right.
      • TheBigC
        • May 2013
        • 5
        Here is a picture of the oven floor and first course.
        • TheBigC
          • May 2013
          • 5
          Here is the just poured insulation layer
          • TheBigC
            • May 2013
            • 5
            Here is a close up of the dried insulation layer.
