Hi all from a newbie
  • Bonnox
    • Aug 2013
    • 5
    Hi guys just came across this website, didn't realise it existed, built me wood burning oven last week and fired it up last night, with mixed results so was searching in how to cook in them when came across this forum
    I think I have attached a photo, its made from a stainless steel keg 3/4 cut then laid flat with the top removed two parts of scaffold poles for chimneys, then covered in a fair few layers of sand and cement, I know its only a small size can really only fit one large pizza I when the coals are pushed back, what do you guys think, I would really like some feedback as I kinda just made it from my mind I didn't really get any advice or read up about them jus looked at some photos and cracked on
    Cheers guys
  • mrchipster
    • Apr 2010
    • 1502
    Re: Hi all from a newbie
    Well, let me be the first to say welcome to the forum.
    If you search out the forum you will find much more substantial ovens.
    Two things are quite obvious, you seem to have no. Insulation so your oven will be really only usable for pizza and othe live fire foods, and you will want a much larger flue on your next oven as I am sure at some point you will get the itch to build a more useable one.
    You should be able to make some good food in this one but...
    I find that even with my 42 inch oven it is much easier to work with several smaller 12 inch size pizzas than to try to manage one large one. And guests really like the variety that can be made with little effort.
    Chip
      • 9211
      I'm surprised that thin pizza stone has not cracked already. Some underfloor insulation with some firebricks for a floor would be my first modification. The two flue pipes do seem a bit inadequate in diameter, although an updraft system does not require as large a flue as a cross draft. The lack of smoke staining on the front indicates that it's working ok. You could also easily cover the dome with 3-4" of 10:1 vermicrete to insulate it, which will improve its performance, then think about making a door. A couple of small upturned tins could be used to close the two flue pipes to retain heat.
      • deejayoh
        • Jul 2010
        • 1893
        I am surprised you can get the pizzas to stick to the roof
        • texman
          • Nov 2009
          • 724
          DJ
          That's funny, i dont care who you are.
          T
          Texman Kitchen
          • Bonnox
            • Aug 2013
            • 5
            Ha ha ha I'd not seen the thumbnail was upside down, when I click omit it seems fine, good tips guys, the bottom 'slab' is two inch of slate so is quite stable and under that didn't seem to get hot so slate seems to hold the heat in quite well I accept you ideas for a bigger flu, I cut a largish hole in the top to fit the pipes in, it's about 6 inches by two but could easily be opened up larger, I was thinking of maybe using a baked bean can sized flu ? Would that work do you think, also would it be best to remove the existing layer of concrete and replace with this vermiculite/perlite concrete mix or can I just put a few layers on the top ?
            Thanks again for the advice guys
            • Bonnox
              • Aug 2013
              • 5
              The flu pipes are both 3.5cm diameter pipes, I could easy upgrade them to a bean can sized flu, would that make it better ? And forgive me to ask but, if the smaller flu's are inadequate why then would I need to close them off to increase heat ? Surely then smaller flus would also help to keep the heat in,
              It would be quite easy to add a big layer of vermacrete to help insulate.
              Also the base is 2 inch slate and seems to be very good at keeping the heat in, the underneath didn't get very hot
              • brickie in oz
                • 3445
                Welcome Bonnox.
                You really need to read the forums on how the heat is retained, there is tons of research to be done on here.
                Start here.
                • Bonnox
                  • Aug 2013
                  • 5
                  Tried getting the Pompeii oven download but it wouldn't let me for some reason cos I'm in the uk,
                  • texman
                    • Nov 2009
                    • 724
                    Pompeii Oven Plans2.0
                    try this link
                    Texman
                    Texman Kitchen
                    • Poetryart
                      • Jul 2011
                      • 50
                      Share
                      | Like
                      brickie in oz likes this.
                      Haha, I was thinking maybe he was in australia....?
                      • Laurentius
                        • Nov 2010
                        • 923
                        Share
                        | Like
                        Haha, he Is!
                        • brickie in oz
                          • 3445
                          I had the same problem because Im in Oz, do a google the plans are everywhere for free.
                          • Bonnox
                            • Aug 2013
                            • 5
                            try this link
                            Texman
                            Ah good stuff got them now
