Re: Experimental Norse-Kiwi Hybrid Oven!
G'day wildflower
Here's a link to Anne's oven showing her formwork
http://www.fornobravo.com/forum/6/ru...tml#post151558
Yours will need to be a little different as Annie pulled hers out through front of her oven and you can't. The end form piece will have to have hole in it so that you can access the inside of the oven. You'll need that as you can then lite a fire and burn the form out, so you had better build it out of something other than a cupboard end like Annie
G'day wildflower
