I've been a hangaround here since 2009, in 2010 I started digging to build my outdoor kitchen. I've completed the kitchen including a stand for a 36" Pompeii oven. Pics will be added later
I am now starting to gather the materials for building. I have a couple of newbe hearth-questions:
- is there a big difference between using superisol plates (Ytong is what you get here) or perlite as hearth? Seems to me to be a easier way out to use plates(?)
- Should the perlite/superisol- layer be placed under the cookingfloor and kept separate from the outer edge of the stand (circular mould inside stand-top), or should this layer cover the whole stand-top. I see different solutions are used, but what is better according to heat-loss?
- what is ultimate thickness of the perlite-layer?
I hope I will be good at documenting the prossess, but it's not my strongest side
And thanks for this site, without it I would have had a hard time researching all the details.
I am now starting to gather the materials for building. I have a couple of newbe hearth-questions:- is there a big difference between using superisol plates (Ytong is what you get here) or perlite as hearth? Seems to me to be a easier way out to use plates(?)
