My name is Jon. I am working on building an oven and have found myself here searching for info. Attached is a pic or 2 of what I have so far.
Greetings from Kentucky
Jon, do you have any insulation under your floor bricks? It does not look like you do.My build thread
Ah, you are following the Alan Scot type design? I think there are a few folks on this site that have built barrel ovens, so hopefully they can help guide you. I know the older designs recommended putting insulation under the hearth slab but that gives quite a big thermal mass to heat so most now recommend putting it under your hearth bricks. It looks like you are pretty far along in your build though, so hopefully access to lots of wood isn't going to be a factor for you.My build thread
Hi Jon. Welcome to the Forum. Best of luck to you w/your Build. You've come to a great place.My Build:
