Hello all, my name is Jason and I am in the planning phase for a 42" oven build once the ground unthaws here in upstate New York. I am a competent carpenter, though I don't consider myself a mason, I have done quite a bit of masonry work. I downloaded the plans as a guide, which I plan on sticking fairly close to. Just have a few questions. The plans don't mention footings below the frost line. I would think I would need these here in NY, am I correct? The rest of the build is in my skill range except for choice of the appropriate refractory materials, specifically mortar. I found a castable firebrick cement made by A.W. Perkins that says it is rated to 2,200 degrees 100$ for 50 lbs. would this make for a suitable mortar for layup of my firebrick? I would think it would tolerate the wide gaps between the brick on the outside well. My other question is about setting up my trammel. What height do I set my pivot point at to get a true prabolic dome? I'm thinking it would be level with the tops of my soldiers, am I correct here? Lastly I would like to incorporate some type of thermometer probe for internal temperature that I would like to be able to read on the outside. Has anyone done this? That is all I have for now.
Thanks!
Jason
Thanks!
Jason
) You can get the same height, and a stronger dome if you use half brick stretchers rather than soldiers for the first few courses. I really don't think that a soldier course is necessary for the larger ovens. Building the dome as a true hemisphere will make it even stronger with no need to buttress. I live too far south to have an opinion on frost lines. And, yes, there are plenty of builds on this forum that have included temperature probes in their builds. Here is a "quick search" of the site for
