Template
  • Template
    Where can I find a layout or template for the 42 inch oven home build?
    There is no template per say. It is something you will need to cut out your self. If you find a build you like some have made very detailed drawings of what they are going to do. Just copy that.
    Randy
      I suggest you look at this link. It is some of the more documented builds of all different sizes. There are so many variables in a build that a one size fits all template is difficult to find. You take the best of all the various builds and use them to fit your need, site, structure, etc. Also suggest you look at the Forno Bravo Pompeli plans, they are eplans and have a nominal $2 or 3 cost. Keep in mind, the eplans are a little dated with many improvements since they were published but it gives you a good baseline to start your design.
      https://community.fornobravo.com/for...n-the-archives
        where can one buy this tool?
          Are you talking about the eplans or is there some other tool you are asking about? If it is eplans it is located at the Forno Bravo store under ebooks and pompeli plans.
