Custom Oven in So Cal
  • Falcon64
    • May 2019
    • 2
    Hey Everyone, I'm Jeff. I built this pizza oven and fireplace for my backyard. I've learned a lot from this forum and also have questions but for now. Hello!
    Pizza Oven Specs:
    Dome is 22" inside diameter
    Dome height inside is 18"
    Opening height is 10"
    Opening width is 12.5"
    Dome is made of fire bricks cut in half so approx 3.5x4.5x4.5" bricks cut at varying degrees to fit snuggly. The dome is approx 4.5" thick of fire bricks plus a layer of refractory cement on top and a scim coat inside. As well as refractory inbetween all the bricks. Then a thin coat of mortar on top
    Base is 3.5" thick. Under oven is made if half fire bricks 1.75" thick . The rest is rebar reinforced concrete
