Brickless in New Hampshire
  • afterburner
    • May 2008
    • 3
    Hi everyone,
    I've been enjoying your posts. Looks like you've got a great online community here. I could use some help locating the low/med duty firebrick in Southern NH
    all the masonary supply places w/in 40 miles sell the high duty 2300deg F kind. Can I use this type? Is there a disadvantage? I'll post some pics soon.
    Wish me luck.
    Pete
  • DrakeRemoray
    • Mar 2006
    • 1215
    Re: Brickless in New Hampshire
    I do think there are a few disadvantages to using high duty firebrick.
    First, they are usually more expensive.
    Second, my understanding is that they do not retain heat as well and tend to be insulating type bricks.
    Third, I understand they they are harder to cut.
    I would keep trying...
    I had to use medium duty in mine and they seem to be fine.
    My Oven Thread:
    • nissanneill
      • Apr 2007
      • 1886
      You forgot one Drake
      I am lead to believe that they also absorb more heat then the lower ones, so you can get your oven too hot.
      As far as being harder, I can vouch for that as I cut one with a diamond brick saw and it was like cutting through a block of steel, so hard, and with so many to cut.... not for this little duck!
      With the number that you will need to make an oven, it will add consideranle weight to the project maybe requiring increased foundations.
      Neill’s Pompeiii #1
      Neill’s kitchen underway
      • CajunKnight
        • May 2008
        • 263
        Welcome to the site. Hope all works in your favor. I was looking on the web and found this one in southern NH. They may be able to point you in the right direction. According to the web search it says they are a brick manufacturer.
        Arthur Whitcomb
        28 Old Homestead Hwy.
        North Swanzey, NH 03431
        PO Box 747
        Keene, NH 03431
        Tel: 603-352-0101
        Fax: 603-357-4850
        like chicken...
        My 44" oven in progress...
        __________________________
        • afterburner
          • May 2008
          • 3
          Thanks all for your replies,
          I was looking at some old posts and this discussion has come up previously. Apparently, the bricks I had located are considered low / med duty. They are used on the insides of fireplaces they are kind of beige in color and weigh about 7-8LBS each. They cost 1.09 each. Next time I'll dig a little deeper into the prev posts. Is there a way to search for a specific topic using keywords?
          Well thanks again.
          Pete
            There is a search function (there is a search tab right below the "Welcome your name" on every page. It has some limitations, it won't search for short words like "UK", but it's sure better than plowing through the directory. The most common problem? for common searches like "fire brick" you will get too many responses, most of them not to topic.
            • Frances
              • Aug 2007
              • 2186
              Don't worry, I only noticed that function after finishing my oven. So you've already got a head start...
              • Baba73
                • May 2007
                • 5
                Hi Pete, Welcome to the forum. I am also from NH. Where did you find those bricks for $1.09? What part of granite are you from? We are from Claremont, good luck with your build. Hope to talk back with you. Aaron
                • TDVT
                  • Dec 2007
                  • 57
                  $1.09 is a good price. There is an Arthur Whitcomb up near here in Barre & they are getting around $1.80 per brick. (Price in March, maybe more now)
                  • CajunKnight
                    • May 2008
                    • 263
                    always ask about seconds and commons on firebricks. They arent perfect but may be usable and a lot cheaper. I will be using the good stuff on the floor tho.
                    like chicken...
                    • afterburner
                      • May 2008
                      • 3
                      I got my bricks from Corriveu-Routhier in Manchester. I'm from New Boston about 30 mins west of Manch. They call them "buffs".
