G'day to all,
I'm in the process of gathering materials and planning the build for a 1000mm internal diameter pompeii oven.
I have managed to find 210 SK34 firebricks (230x115x65mm) and approx 50 insulating firebricks (isolite B8)
From what I have read on the forum my plans are as follows, any improvements / feedback is welcome
Base-
re-enforced concrete on dry stacked blocks (core filled with reo)
Mosaic tiles with drain holes in the slab, should water ever make its way in (will be in an undercover area)
Insulating firebricks 230x115x65mm
CalSil board - I'm debating weather to go for 1 inch or the 2inch thick as there is significant insulation provided by the insulating firebricks..
SK34 fire brick base, herring bone pattern with slight chamfer on all upper brick edges
Dome
Dome to be built on top of the base to ease any thermal expansion issues
Bricks will be cut using the "Mr Chipsters" Jig in conjunction with the pompeii dome calculator spreadsheet using I.T. method construction
Mortar- Unsure to make my own "homemade" or buy the high temp premade bags
Insulation Ceramic fibre blanket, 2 rolls making approx 100mm layer over the dome
Chicken wire and roof tile pointing to render (stucco coat) and potentially tile as final layer
Inner arch and Flue arch
SK34 fire bricks for the inner arch using the same dimensions as Mark Jerling provided in his plans
Outer arch, Depending on qty of bricks remaining might use fire bricks or just general kiln fired bricks
Looking for guidance on weather a thermal break is going to be worth the effort.
The outer arch is the part I'm not completely sure on how to construct and tie into the inner arch.
From what I have seen having a taper leading up to the flue on the surrounding bricks would help with draw and prevent smoke coming out the entrance
Look forward to any advice or tricks to help with the build..
Cheers...
Base-
Dome
Cheers...
